It is currently 29 Jul 2026, 21:14
Another of my favorites, Hamilton QED Time only
Phasar66
Post14 May 2012, 04:32
I really like this watch, it has personality.
Re: Another of my favorites, Hamilton QED Time only
Post14 May 2012, 19:19
nice and clean..great work and a nice watch.....my other hamilton has a color difference in gold between the case and the band..this looks like it the same color?
Phasar66
Post14 May 2012, 19:24
I seen that before and is the case which differs in color. Are there any 14 and 10K GF?
Post14 May 2012, 20:00
yes..10 an 14..and thats the differend in color..but yours is the same?
Phasar66
Post14 May 2012, 20:24
Mine is 10k GF, but then a got a case with no case back with the difference in color.
so I suspect its a 14K, a little more yellow. The bracelet is just like the one on this watch.
Post15 May 2012, 01:35
Nice. Definitely a classic.
The crystals on these early QEDs have the logo applied using some sort of gold leaf process rather than the baked on glass powder approach used in the later models.
On the plus side, the logo is shiny metallic gold rather than yellow. On the minus side, it seems as though the metallic gold crystal logos were extremely fragile. I have an example with almost no wear and an almost perfect crystal except that the logo is partially worn off. I haven't seen an example yet with an undamaged logo. Anyone have one? If so, post a photo!
Post15 May 2012, 23:08
Crystals of this type were done for all the "big three"; Hamilton, Pulsar, and Omega. Looking at one under high magnification now leads me to believe that the logo is not done in gold leaf. At 90X there is still not the slightest suggestion of any "thickness". I'm guessing now that this was done with some sort of "masking" process, where the lettering was left open, and the rest of the surface was covered in some removable material (this is very similar to the way printed circuit boards are made). Then, the glass was placed in a vacuum chamber, and pure gold was evaporated on it. The masking material is then removed, leaving only the gold lettering behind. The result is pretty, but has almost no durability, due to the thinness and softness of the gold. There are also laminated sapphire timescreens for the Pulsar Pulse-Time and Classic that have silver logos done in similar fashion (except the logo is on the underside of the clear sapphire top layer, and had to be done in reversed lettering, in order to read correctly; this did seem to adequately address the durability issue). These crystals are quite rare, also.
nipper1
Post16 May 2012, 00:27
i also love these . this is my one time only no date on this one . single button only .these are rare :-D
Phasar66
Post19 May 2012, 03:53
Yours is a very nice watch, yes are rare and it looks pristine.
nipper1
Post19 May 2012, 09:13
yes was lucky with that one perfect crystal and all the brush finish still on watch band no scratches no where . no one ealse put bid in 5 months ago . as it was just under Hamilton :-D
Phasar66
Post19 May 2012, 09:40
Feels good when you get lucky. Nice catch.
I
Return to Omega and GP
