It is currently 02 Mar 2026, 20:29
Needed: reliable 1Mhz Xtal
elceedee
Post16 Feb 2013, 16:35
Im looking for a reliable tube shaped 1Mhz Xtal with the measurements: diameter 3 to 4 mm , length 8 to 10 mm.
A smaller size is allways okay.
Off course it needs to have workable connectors (not cut off too short)
Thanks!
Re: Needed: reliable 1Mhz Xtal
Post17 Feb 2013, 01:14
I do have SMD 2Mhz 12pf xtals if you have use for these.
elceedee
Post17 Feb 2013, 01:19
Thanks, but unfortunately this watch runs on 1mhz, i cant trim a 2mhz
