It is currently 28 Jul 2026, 06:26
Seiko c439
Seiko c439
Post20 Feb 2014, 22:44
Hi again :grin1:
So I now have a seiko c439-5010.
The circuit is perfect as is the LCD. The case needs some work but is pretty good. Restoration should result in a perfect watch however, as per usual, parts!
I need the rubber keyboard gasket that sits and holds the keyboard bezel. The original is nothing but crumbly dust!
So any donors out there or parts (Seiko kid has a pm :-P
Now until I get a donor or parts I have assembled the watch without the keyboard and keys. I have tested all functions but the tech manual does not tell you how to activate the alarm, only to set it. Setting is easy, but how do I get the alarm indicator to show (ie get the alarm to be active)?
Cheers
Re: Seiko c439
Post21 Feb 2014, 12:42
If you find a source, get me one too :-D
Re: Seiko c439
Post21 Feb 2014, 20:37
I have the correct name for the part but no number!
"Keyboard frame"
:bang:
How does one activate the alarm, that is, how does one get the alarm icon to show? Setting is easy, but without a manual :bang:
Also the tech manual is just for the movement but does not describe how to activate the alarm. I know it has the icon showing an active alarms as it show up on the "all segment test". Also, should be a time signal according to the tech manual.
Anyone with a manual they can scan, anyone :?: :!: :lol:
elceedee
Re: Seiko c439
Post22 Feb 2014, 00:01
I have a manual in PDF with a parts list. Pm me with you email address, ill send it to you.
Regards
Re: Seiko c439
Post22 Feb 2014, 02:57
Hi and thanks! I would appreciate the manual! :grin1:
Just to be clear, I have the tech manual for the c439 with the movement parts list. It does not tell you how to activate the alarm, only how to set it.
It also doesn't have the case parts list and the keyboard frame is a case part.
Cheers, Geoff
Email sent and thanks for the file :-D
P.s. Off to Sydney Australia tomorrow and will drop by my Seiko parts guy there. He has casing info and maybe some parts. Will get extra if they exist. Fingers crossed.
coconutman351
Re: Seiko c439
Post04 Jun 2022, 19:58
Hi Geoff, were you able to find the keyboard membrane for your Seiko C439A, seems like a very common problem with these models.
regards,
Robert
coconutman351
Re: Seiko c439
Post12 Jun 2025, 05:54
I just restored a Seiko C439 and to enable the alarm function, you have to press the A and B buttons to enable the alarm and show the alarm icon on the LCD screen. Yes the technical manual does not state how to enable the alarm, only how the set it. Big oversight!
