It is currently 27 Apr 2026, 11:04
Realtime 1976 restore
supercasio
Post01 Apr 2014, 08:29
Hallo.
I'm restoring a vintage Realtime LCD about 1976 (my first watch with a great sentimental value) but the module has serious problems: it works but after 1 day it's 1 or 2 hours late, after 3 days the battery is fault. I changed two battery, replacaced the quartz, adjust capacimeter but nothing and now the copper tracks are rising up and plastic rim is broke.
I think it's time to change the module but for his particulary thickness is not easy. Have any suggestions o replacement?
I'm available to put one similar also because the dial print is made by myself and I can reprint with a different display position but the fomat has to be in 6 digit, 24h, light, date and if present chronograph and the buttons must match.
Thanks in advance.
Re: Realtime 1976 restore
Post01 Apr 2014, 15:13
Welcome to the board from all us.
These are not easy to repair, better search for a new (old) module. I will have a look if i can find anything that matches. Where are you from? Update your location in your personal prefs.
Btw i'm interested how you did the new dial.
:dwf: "willkommen"
supercasio
Post01 Apr 2014, 15:27
Ok, thank you. Profile updated. Waiting some news.
Post01 Apr 2014, 16:32
supercasio wrote:Ok, thank you. Profile updated. Waiting some news.
Welcome Italiano!! I'm from Milano.... ;-)
supercasio
Post04 Apr 2014, 12:48
At the moment I'm trying a temporary job. Have found an identical module, same functions but 1,5mm higher and 1mm smaller but I adapted it.
It works fine, but I have to find a back cover more deep (diam.34mm on case, 35mm cover) so I can use it. Help?
I'm conscious that is just a temporary replacing waiting to find his original module but the emotion to see it alive is great!
Any suggestions about to switch this module (3 buttons chronograph without MODE) fron 12 to 24 hours? I'm became crazy about it.
Thanks.
supercasio
Post27 Feb 2017, 18:15
Ok, some news, after a couple years of research, I found the module and restored the watch. I made a new face with my PC as original printing and cleaned the case.
The problem now is the AM/PM setting that I have by default and have no way to change in 24h. I'm thinkig maybe is a US version but the display, in chronograph mode, it works in 6 digits!
I am conscious it is just a cheap watch, but remind my youth in the 70's and I'm so happy to see it again alive.
