It is currently 26 Aug 2026, 19:36
Cristalonic Time Computer - first LCD watch with solar cells
Post04 May 2017, 21:46
I tried to find one of these for some time. Now I have one... :-D
Basically, as one may read on Doensen book - WATCH. History of the modern wrist watch:
"1976 - The first watch with solar cells and LCD is the 'Solar Quartz' by Cristalonic Time Computer GmbH of Munich, Germany, who showed the watch at the Basle Fair in April. "
https://doensen.home.xs4all.nl/n2.html
https://doensen.home.xs4all.nl/fotos/N1a.jpg
As one may see in the photos below (including some copies of adverts from Basel European Watch, Clock and Jewellery Fair April 24 - May 3, 1976), this heavily Gold Plated version of the Cristalonic was among the ones presented at the Basel Fair 1976:
Re: Cristalonic Time Computer - first LCD watch with solar c
Post05 May 2017, 23:29
Just to raise the discussion about "novelty claims" a little, I will tell You that I am waiting for OR have already also the other two RARE Mondaine/Mirexal/Swiss Made SOLAR watches of 1977, with a Brown Boveri made display - where "One model was issued with an eight digit-display and a second model with a 10 digit-display.", as it is mentioned in the Doensen book or on the soluhr.com website:
http://www.soluhr.com/mondaine.htm
And I have/will have soon both of those models... :-D
So my straight question is:
Did you ever seen/know about a watch with 10 DIGIT display until mid' 80s - e.g. Casio Ca 601, 10 Digit watch (1984 ) ???
http://www.newdwf.com/viewtopic.php?f=67&t=8400
Thus, what do You think that those "classical" sources meant by a "8 OR 10 digit displays" at that time??? :scratch:
I will highly appreciate any opinions from the forum's members... :Prost:
PS: below is a famous Swiss Company Brown Boveri prototype (which never seen the market!) of a LCD watch with "8 digit display" from 1973 :grin1:
http://ethw.org/First-Hand:Liquid_Cryst ... tributions
PG101
Post07 May 2017, 00:00
Well according to the "History of Longines", on their website here: https://www.longines.com/company/history/19th/1832, their first LCD watch had an 8-digit display in 1972.
This was the watch:
Post07 May 2017, 19:18
Thanks PG101 for this interesting information about the first LCDs (DSMs looking like FEs displays?!??) with 8 digits. :Prost:
I did not responded sooner because I needed to document a little these amazing 1972-1973 8 Digits watch prototypes. :grin1:
So what I've found is that - basically - BOTH the Longines and Brown Boweri was about the same thing produced in 1972-1973 by Ebauches SA (=ESA) in two different collaboration:
I. (n.r. for sure a DSM - Dynamic Scattering LCD!) made by Ebauches S.A. (ESA)+ Texas Instruments (integrated circuit!) + Longines
Caliber ESA 9260 of the 'Swissonic 2000' line, produced by Ebauches S.A. (ESA), Longines and Texas Instruments (n.r. probably the IC!) with the name 'Clepsydre' reaches the market. Only very few watches were sold by Longines. In 1972, this watch won a prize as one of the hundred most advanced products of the year 1972, awarded annually by the 'Annual Research Conference and Awards'.
https://doensen.home.xs4all.nl/l1.html
Please note that Doensen's book have mentioned that "Only very few watches were sold by Longines." while Hyltin book (1978) - The digital Electronic watch mentioned at page 8 that the Longines watch was not built "in production quantities" - THUS we may talk probably about some prototype/demo watches for International Exhibitions!
II. Probably also a DSM module - made by Brown Bovery + Ebauches SA (ESA) + Philips/Faselec (Integrated Circuit)
[i]"Prototype displays were made for a joint-effort wristwatch project that we did together with Ebauches SA, the major Swiss watch movements manufacturer (now part of the Swatch Group) and Faselec (n.r. the IC), the Swiss IC subsidiary of Philips. A working quartz digital wristwatch was shown at the MUBA fair in March 1973. It contained chips made by Faselec and our 8-digit TN LCD."[/i]
The only thing that it should be also clarified is WHY both those above mentioned 8 Digits prototypes may look more like a more modern FE LCD display than a DSM display (black digits on white screen, instead of creamy white digits on a black displayas regular DSM display! :grin1:
And the EXPLANATION is that - while it is not very known - ALSO the DSM LCD could be used not only in "reflective mode" (using a mirror) - as most other DSM displays, but also by using a "black back plate" when the digits may look BLACK on a white screen, as one may read below, on the Doensen Book:
"The surrounding light goes through the front glass, a liquid crystal layer of 0,025 mm thickness, and is absorbed in the black back plate. On both glass plates, conductive transparent electrodes are attached. When a voltage between 10 and 20 volts is applied on the electrodes, the arrangement of the molecules is destroyed by the collisions of the moving ions, scattering the light and causing this part of the LCD to look darker than the rest of the display.
By replacing the black plate by a mirror it is possible to use the cell in a reflective mode. The segments which are not energised let the light go past, which will cause the mirror to reflect the light and compose the digits. The layer in the electric field between the electrodes scatters the light in all directions and looks dark. When no voltage at all is applied, the display is clear and the parts which are mirrored can be seen. The latter display has been applied the most. "
as one may see in the picture below ( Hyltin book (1978) - The digital Electronic watch ):
Post17 Jan 2020, 12:21
A new adittion to my small collection, a rare Cristalonic Solar Quartz from the first generation solar LCD of cca 1976:
this time a rarely seen (the second one I've seen, the first being on the URL below) SOLAR LCD watch made by Cristalonic Munchen for the French MATY watch company:
https://www.worthpoint.com/worthopedia/vintage-maty-christalonic-solar-466902853
The watch with a FULL SS case and original Cristalonic vintage SS bracelet:
and the caseback with - now very fashionable - ANTIPOLLUTION tag :grin1:
Users browsing this forum: No registered users and 50 guests
