It is currently 25 Apr 2026, 12:11
Tissot digital world recorder 15MR26 help
Brianch
Post10 Oct 2017, 09:52
Please does anyone have instructions for this 1970's piece that I can buy or receive in scan form in order I can set the watch? Any suggestions much appreciated.
Brian
Re: Tissot digital world recorder 15MR26 help
Post11 Oct 2017, 07:49
Picture would help, but isn't this one of the Tissot's that used a NEC (Casio) module? I think it is the same module as in the Casio 29CS-11 watch but without a photo.......
Brianch
Post11 Oct 2017, 10:13
Thanks old Tom for you reply, I hope you are right. I have attached a photo. The digital watch library web site does not have the manual for the watch under TISSOT but does have the casio model so if you are right....!
Post11 Oct 2017, 11:06
I did look but I don't think I have that one for the library, so if you do find it i'd love a copy in pdf so I can dd it. Does the Casio 29CS-11 use a different lcd panel Tom? I had the module as Module 17
http://www.digital-watch.com/DWL/1work/ca1S-14
Post11 Oct 2017, 11:35
Not the module 29, instead the NEC (Casio) module 17= check & compare on google images
Brianch
Post11 Oct 2017, 11:58
Adam and Tom...Thanks yes will do regarding a pdf. Please bear in mind I am a complete novice with electronics, will I be able to download from somewhere in order I can set and use the watch? As a point of interest, I contacted TISSOT customer services who replied very quickly advising me that for them to make a search in their records for watches no longer produced I would have to pay them a minimum of £100. I will pass on that obviously.
Brian
Brianch
Post12 Oct 2017, 09:51
No further forward on this one. I imagined this was a reasonably common watch but it seems not. I have googled various modules but it hasn't helped. I will have to try to work out how to set it.
Brianch
Post12 Oct 2017, 12:27
Regarding the TISSOT, here is the workings. Maybe this will confirm the module and maybe help to offer some ideas on how to set it up?
PG101
Post12 Oct 2017, 21:33
Brianch
Post12 Oct 2017, 22:28
Thanks for looking PG. I have asked him
Brian
Post13 Oct 2017, 13:18
Brianch
Post13 Oct 2017, 16:26
charger105 wrote:This may help:
viewtopic.php?f=58&t=6025
Thanks Andrew.... copied and working through the instructions now. I think I understand it and it will be working soon. Thanks to all for help
Brian
Users browsing this forum: Google [Bot] and 24 guests
